Question about Apple Ipad I-pad
Connectiong to the internet
Talktalk help page gave this address to find and confirm router details to connect iPad to internet
  • 57 Answers
To connect to internet , you can connect wifi via your own connection or a known one.... and just use the password and your on.... you only need to access your router webpage to figure out your wep passcode...
Posted on Nov 23, 2011
SOURCE:
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Dec 26, 2012 | NetGear DGN1000 Wireless Router
"MAC Address Invalid" message
Good old TalkTalk. The easiest way is to phone their help line.
Jun 11, 2017 | HP Computers & Internet
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Could not access my dlink router di-524 using 192.168.0.1
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
May 14, 2010 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Can not access the 192.168.1.2 ip
Hey achek76,
I would assume you are trying to reach for router configuration page via your internet browser.
The first step I would take it to confirm this is indeed the correct address for such a page. In order to do this follow these steps:
  • Start >
  • Accessories >
  • Command Prompt or CMD
Once opened you should have what looks like a black box that you can write text in. Write in the following command:
  • ipconfig
Once this command is wrote you should get output that looks like this, along with some others but we are only worried about one and that's the default gateway which I have made bold. This will be the address required to reach your router configuration via your internet browser. (Ignore the address you see here as they are mine and are no use to you.)
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . :
IPv4 Address. . . . . . . . . . . : 172.16.121.51
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . : 172.16.120.1
If you confirm you are using the correct browser I would then proceed with resetting your router via the small pin hole located on the back, this will restore it to factory defaults and maybe clear up any problems the router is experiencing.
Once reset run the command I mentioned above and check your default gateway again and type that IP into your browser to access your router configuration.
Hope this helps!
Thanks for using fixya!
May 14, 2010 | Zyxel ZyAIR G-570S - Wireless access point...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Have philips wireless modem from talktalk but dont have installation disc. need to install mamnually
I think this is a wireless router, and therefore does not need an installation disk.
all you need to do is connect to the router (using a lan cable if you cannot connect to it wirelessly) the default IP address should be 192.168.2.1 type this ip into IE you should get a configuration page and then you should then be able to configure the rest of the settings yourself
see info below
http://www.talktalk.co.uk/talktalk/servlet/gben-server-AssetServer?article=MAIN.UK.TALKTALK.STATIC.HELP.MODEMTYPE&asset=PDF1
Apr 10, 2008 | Computers & Internet
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Apple Ipad I-pad Logo
76 people viewed this question
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
