Just moved my treadmill and now most of the buttons are non-responsive. Start and Stop work, speed + and - work, incline + and - act like they are working, but nothing actually moves. NONE of the program select or one-touch speed/incline buttons are responding, no response from the fan button or Display buttons. No beep, no activity. Tried resetting and calibrating. Incline salibration sensor reads Zero. Cannot get the machine out of manual / 0% incline mode.
Http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
1) check the wiring from where your power adapter plugs into your machine to the console. 2)Check continuity FOR fuse and reset breaker 3) adjust the Sensor Reed swith see the schematic 1/8" very important. 4) Test the transformer see the tip.5) If everything is o.k the console panel would be faulty.
The incline feature does not work. When I do the initial incline calibration on the console, it gives an error message that it can not be performed. Even the manual incline buttons will not work. Everything else works fine.
touch screen little or no response. if i push stop and start simltaneously then let go of stop it will go on speed 1 but cannot adjust.no other buttons work
