Error code e0001
SOURCE: when i run fifa 11
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps
SOURCE: I installed Fifa 11 When i
This is due to your graphic card not supporting "Layer 3 mode or better". You need a better graphic say with "layer 4 mode" support to play the game.
FYI
ATI Radeon HD3200, HD4350 and
Hope it helps.
Testimonial: "Well thanx i got to know the problem otherwise BTW can it work on ATI Radeon 3450"
