Xerox DocuColor 12 Printer Logo
My xerox dccs 50 needs setting for even printing ... Plz help.
My above printer was giving faint printing in the back side and ok printing in the front side of user panel throughout the paper. One technician came and changed the setting and told me that he has kept the back side portion i.e. The left side of the paper, in extreme high position. After that, i am getting left side deep and right side light. I want to make some changes in the setting. I know, how to enter menu by pressing 0 and start and password 6789. After that i dont know how to change the setting by which i can change the left side or make the right side high value. Kindly help me. Regds binay
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Dec 09, 2008
SOURCE: ROS Trouble with Xerox DouPrint N17
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Anonymous
  • 679 Answers
  • Posted on Jan 07, 2009
SOURCE: Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Centreware password on Xerox 7335
I called Xerox and they had to send a tech to reset the password back to factory. The factory set is username x-admin and password 11111.
Anonymous
  • Posted on Dec 12, 2009
SOURCE: 2 sided printing problem
Go to the printer in your printer folder in control panel. Right click on it and select properties. Then select the last tab named "Printer" and click "Get information from printer button". Hope it helps you.. works for me.
Jonnhzz Chan
  • 186 Answers
  • Posted on Feb 18, 2010
SOURCE: Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
4answers
1helpful
Xerox DC12 Fiery EX12 Print missaligment
caopy can be set by NVm Code 720-001 for side A
720-002 for Side B
please note down initial values before changing it
45helpful
2answers
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Black ink is faint
2answers
Very faint printing in xerox 3117 laser printer
my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
