As grubhead implies, there is more to making a unit work on 'foreign' power than just making the plug fit in the socket. You don't say what was the input voltage used versus what it needs. It sounds like a 220 in to a 110 required device. Potentially it's toast unless the in-line fuse saved it. I'm sure the manual would have cautioned against what happened.
It could be the adapter is just faulty, but you can't tell to you get power to the unit if any part has failed inside (most liklely the transformer if it has).
I found this step-down adapter on amazon which should do the trick, not expensive either.
http://www.amazon.co.uk/Stepdown-240-120V-Transformer-45VA/dp/B000NJ26X2/ref=pd_cp_ce_1
Hello, I think I have done exactly the same thing as you... Have you had any luck? Please reply! I don't have a clue how to fix it.
