Blue screen Hello,i have my tv JVC AV-27120 27" and doesn't want to show any chanels....only a blue color screen.So,i conected the cable ,than i put automatic searching and after it finished to search,the TV show the same problem...every chanels blue color but not programes.Can somebody to tell me what is the problem?...Thanks.
The standard colors are : White, Yellow and Red. If you match the Red of the TV, the White of the TV and the Yellow of the TV to the same colors on the DVD player, then all should work properly. It does not matter what color the cable is, match color for color on the devices. Hope this helps and good luck from a teacher to another teacher.
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Here's a link to order the original JVC remote controller for this model (AV-20220) from a major parts distributor if you need the remote to fix the colors on your unit:
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
what you need to do is go into the menu and select the channel program, so the tv will find any channels that are coming through the cable line. so make sure the input is set to cable and tv.
