I have a Mirage Split A/c with remote. The remote does nor work, no led information, blanck screen, out new battarries no go. Bought a VTRONIX Universal remote, but no codes for mirage. Company went out of bussiness in mexico. Need codes for new remote
Might as well purchase a Popular Universal Remote that is capable of handling a Mirage Split AC.Might as well purchase a Popular Universal Remote that is capable of handling a Mirage Split AC.
You can't post conmments that contain an email address.
Are you saying that the same picture is split into two, or that there are 2 images split on the screen? Might be the PIP board or setting on the remote that is bad.
Hi there I have an LG50PG6010 that did the same how I fixed mine was simple I took off the back then removed the board that has all your connections on it like your hdmi and scart ports hen I turned it over and only do this if you feel comfortable doing it and I did it on my cooker. I took a heat gun and heated the board I held it about an inch away from the board and did circular movements sort of like a reflow to make the solder catch again if this doesn,t work it doesn,t matter as you,ll probably need to replace this board anyway
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
power on.
press and hold the down volume button on the TV and the split button on the original remote together for over 5 seconds.
It should reset the timer and the lamp led should go out.
There is a button behind the front panel on the Wii, and a red button behind the battery cover on the remote.
With batteries in the remote, push the red button on the remote.
The LEDs will blink.
On the Wii, push the sync button behind the SD card front cover.
When the blinking on the remote stops, it is synchronized.
The LED that is lit is the player number.
Use this method for any more remotes you want to add.
