I cannot get the slack out.there are 2 nuts only 1 nut grips the blade when I put the chain on
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Reinstall chain
I have a Remington 16" electric chainsaw and I have the same problem. It is VERY hard to line up the chain adjuster (I guess that's what it is called. The thing that has a TINY protrusion to go in a hole and then you turn the handle and TRY to tighten the chain) with the hole in the blade (?). Once you do get it alligned and cut for just a little while the chain comes off. I think I have it tightened right, there is a very small amount of slack in the chain. Works fine for about 5 minutes if you are lucky and then the chain comes off and you have to start all over again. Am I missing something? Is there some very simple easy way to get the adjuster lined up with the blade (I guess that's what it's called) so you can tighten the chain and then a very simple way to keep the chain from continually coming off? Help
