Want to upgrade my router to the latest firmware but the process always fails when you run it through the browser interface. anyone know where to just download it so I can point at it on my hdd?
Eh..some yes, mostly NO! I am a technician for the company that widely set up these type routers/switches/gateways and the simple problem is that most of these were used during installation by BellSouth which is now technically SBC Doing Business As; AT&T, DBA BellSouth Mississippi, Louisiana, Alabama,ETC.
follow this link
AT Drivers and Downloads
and select your model of the Netopia 3000 series you have and click the firmware link. DO NOT RUN THIS FILE. IT IS A .BIN FILE TO BE USED IN THE ROUTER'S UPDATE FIRMWARE SECTION. Go back into the update firmware menu and instead of choosing the automatic or online feature *previously a BellSouth domain now converted to an AT&T ITservices domain which is why it can't find it) choose the browse or select file option and select the .bin file you saved and that should do it.
SOURCE: tried to update firmware nir82R1. Got update
That wont help either!!!!!!
What you can try is .....try once more to update firmware in case you still get that same message.Please get in touch with technical support of Netopia ask them to update your firmware
Hope this will resolve your issue
SOURCE: netopia 3347nwg wifi locked!!!
Hello michael,
The lock you see indicates that the network you are trying to connect to requires a password for authentication.
You can access your ipod settings and enter the credentials by following the below steps:
1- First connect to your closed Wi-Fi network
2- Choose Wi-Fi, then tap Other and enter the network name.
3- Choose Security, tap the type of security the
network uses, and enter the password.
This should be it.
Have a good day.
SOURCE: Will not upgrade to latest firmware
The newest firmware version is actually v 2.01.
The file should be called DI634M_firmware_201.bin and is engineered for North American products only. Does that apply to you?
You can get the file here.
Important! - Make sure that you use only hard-wired network connections for upgrading. Do NOT upgrade firmware on any router over a wireless connection. This might result in a device failure.
Here is also a page with detailed instructions.
If you have any more questions or this doesn't work for you, just come back here and leave a comment - I'm happy to help.
SOURCE: I have a Netopia 3347NWG-006 Router. I want to find my DNS server setting.
Click on this WEB site to check if your computer is infected with the DNS changer.
http://www.dns-ok.gov.au/
You will find ADMINISTRATION tab in
the upper right hand corner.
click on the
administration tab. just below the administration
tab you will find firmware upgrade sub
tab. Click on Firmware upgrade.
Now on this window you
will find browse option.
click on the browse button and select the firmware file that you have
downloaded on the computer. after selecting the proper file click Upgrade. The
upgrade process will start.
It may take 2 to 5 minutes.
once
you upgrade the firmware of the router, unplug the power cable of the
router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router
Upgrade
# Click Browse and find the file you just
downloaded.
# Click Upload. Do not interrupt the
upgrade while the router does this step.
It may
once you upgrade the firmware of the
router, unplug the power cable of the router , wait for 5 seconds and
plug it back in.
For Belkin router
Open a
web browser on the computer.
In the
address bar of the web browser, type http://192.168.2.1 and press Enter
on your keyboard.
Click
Login in the upper right-hand corner of the page.
The router does not ship with a password, so just
click Submit.
Click on "Firmware Update" toward the bottom of
the left-hand menu.
Now on
this window you will find browse option.
It may
once you
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Now on this window you will find browse
option. click on the browse button and select the firmware file that you
have downloaded on the computer. after selecting the proper file click Upgrade. The
It may
once you
