Cell Phones Logo
Posted on Sep 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot send texts as phone says no space for text message but I have cleared inbox, outbox and sent messages
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Sep 27, 2008
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
15605
Points
120
Its a software bug.. you have to re install the software.. contact a LG service centre as soon as possible
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
768
Points
Make sure all your contacts are on the Sim card and any data in phone memory is saved. Then go to the settings section and use the "RESET ALL" function to reset the phone.
This solved the same problem on my KF300, but it did delete all my contacts, hense the warning above
Ian
While sending text message it says memory full delete some data?
hi..
This is because when you send the message it stores up in outbox and then only it wil be sent,As your phone memory is full no space is there for storing in the outbox. So please delete the inbox and draft and savedmessages so that you will not get this message again.
Thanx
How do you text
follow the steps below to send text
  1. login and select 'Send New Text Message' link from the Inbox, Outbox, or Pending views.
  2. Type in your text message and save for sending.
  3. Run the Motorola TEXT application on your phone, and your text message will be sent. Your message record will be moved out of the Pending folder into your Outbox online.
Text full, but really isn't
did you try checking if there was any text messages saved to the memory card or the phone itself.
6helpful
2answers
MY TEXT MESSAGING WONT LET ME TEXT ANYONE. IT SAYS TEXT MESSAGE FULL BUT I HAVE NO MESSAGES IN MY INBOX OR OUTBOX
Does it show signal bars on the screen and are you able to make/receive calls? If not then that is why. AT&T does not guarantee in building service. If you do have signal and it is working other than text, then check your message center number in the device:
From the standby screen, press Menu.
Press Messaging.
Scroll to and select Settings.
Scroll to and select Text Message.
Enter appropriate Message Center Number, then press Done. The message center number that should be there is +13123149810 (and the + sign does need to be in front of it)
Can't send texts
pls delete some text messages in the inbox, outbox, and sent items to have enough space... tnx
2answers
Text messaging
clear messages in your inbox outbox and drafts to clear up space. restart the phone. then try sending message
5helpful
4answers
RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
1helpful
2answers
Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
No inbox or Outbox, or sent message folder
try master resetting the phone see if that helps it
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
