I can take continuous amount of photographs but after 20 shots the busy message flashes on the view finder. Therefore not allowing me to take anymore images until it disappears and when it does can only take one shot at a time. Never use to happen only recently and becoming more annoying.
This sounds like a flash configuration issue combined with the continuous shooting mode, which will take 3 pictures in rapid succession and display "busy" while the flash is recycling. For starters, switch it back to single shot mode. That's the button that looks like the stack of pages and the timer clock. Then turn off the flash. That's the icon with the flash lightning image with the bar through it. You will probably need to adjust your ISO, shutter speed, and aperture setting to get a good low-light shot.
I had the same problem, camera is only 5 months old and still under warrenty. I sent it into cannon for repair...mother board was shot...new board installed...have used the camera 2 times since getting it back...camera has died on me again...same problem. Have to send it back again! Don't recommend this camera to anyone!
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering. if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview. with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting! after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again. you can repeat this few times and you be lucky if you 30 pics captured:) REMEMBER: all this goes without camera flash!!! flash and every zooming use more battery power! and that was all magic:).
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else. This camera is going back to the store if I can't get some help. PLEASE............. vj
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
Guys - I just recevied a new H9 today. Was using it and decided to turn
the flash off. Later on I wanted to turn it back on and I got the
famous "flash settings cannot be changed" error message. I found the
problem. I had turned on the "continuous shooting" option as I wanted
to see how fast it would take photos continuously. When that option is
on, you cannot use the flash so therefore you cannot change the flash
settings. I put the camera back in "single-shot" mode and now the flash
works fine. I hope this fixes your issue.
