There is a short or badly installed light bulb in the rear brake light housing. Those bulbs use both running lights and brake light filaments and if a filament shorts to the other filament or they are installed wrong, pressing the brake pedal energizes the brake light and inturn the running lights.
FLipSHARE software isn't compatible with Vista Aero and some other visual settings, SO, when you plug in your Fllip camera, the FlipShare software changes your desktop settings to go with their camera. They should go back to how you had visuals set before the camera was plugged in once you remove the camcorder. No green light shows when charged, a Red light shows up and glows during charge and when the red light goes out it is fully charged.
this sometimes occurs with age due to egr and intake becoming carbon filled , inturn requireing more vacuum inturn raising rpm to keep up , check all vac lines for poss leaks this will cause prob , to check for leaks crank engine let idle use can of wd40 or starting fluid and spray lightly around suspected area , if rpms raise when u spray then u have found ur leak
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
The video out chip may have blown or come unsoldered
