Well ive tried to play my music on my lg bl40 headphone icon stuck on its in car kit mode i think
SOURCE: car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
SOURCE: detailed user manual for the LG bl40 chocolate phone
Here it is
file:///C:/Documents%20and%20Settings/James%20Roden/My%20Documents/Downloads/BL40g_TELUS_Eng_apprvd.pdf
Tried the link and it works from google but not if you insert it into the address bar so if not here is what I typed into google, maybe you can cut and paste it.
lg "BL40" manual instructions user guide booklet
Should come up as top result pdf file
Jim
