Not sure what sort of problems because you have not stated you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
hope this helps you
SOURCE: RE: 2GB Kingston on MAC OS X
The drivers are needed only for windows 98 and back. Xp, mac all do not need drivers for the thumb drives.
May be something else is wrong... mostly software related.
The DataTraveler is just a Flash Drive... Are looking for a virus scanner? Do you want to check the drive for viruses?
