In bottom of the freezer it accumulates water and it freezes so i know its cold enough to freeze. i don't hear the ice maker cycling and water filling the ice maker like i used to; also, the arm is very 'loose', it doesnt seem like its engaging correctly.
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
SOURCE: GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
SOURCE: ice maker tube freezing up
SOURCE: GE Profile refrigerator ice maker stopped working
I have the same issue - call GE, give them your frig model number and they can get you the part nmber of the valve. GE charges about $75 with shipping - you can find it on line for about $45 - I went with GE original parts....it's a pretty easy repiar.
