Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
Why don't you just clean it?
Very carefully use a soap pad, and then dry thoroughly. remember to dry thoroughly after every use, and wipe a little veggie oil on the blades with a paper towel.
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks. Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it. I hope this helps. If it does, please come back and rate my suggestion!
Once you receive the parts, unscrew the collar from the bottom of the jar, and the old gasket and blade assembly will pop out - sometimes you have to peel the gasket apart from blender jar, but not always.
I wish I could tell you a definite solution. Have you tried calling 973-575-5400 (ext 129)? I realize it isn't toll-free. According to several web sites, the manufacturer has discontinued the product, but they should definitely still be supporting the motor warranty.
Mine is eating the bearing in the bottom of the pitcher. That seems to be everyone's most frequent problem although mine hasn't actually started to leak yet. The motor is just fine. I suspect Jack Lalanne started getting complaints about the pitcher bearing and dropped his support for the product because of that.
