Question about Rolex Datejust Watches
How do I change the day and date on a Rolex Date Just Oyster Perpetual watch?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Posted on Feb 11, 2018
5 Suggested Answers
SOURCE:
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
Posted on Jan 05, 2009
escapement
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2338 Answers
SOURCE: I need an owner's manual for a Rolex Oyster
Posted on Mar 31, 2009
  • 65 Answers
SOURCE: Oyster Perpetual Day Date keeps stopping
That does sound like a peculiar problem. Without looking at it it's difficult to say. It possible the date change - stopping situation is co-incidental. All mechanical watches, particularly high quality one such as this should be serviced every two to three years to ensure optimal performance and preserve their value. I recommend you take it to a qualified repairer. Good luck.
Posted on Jul 28, 2009
Winding stem comes all the way out and I can't reset the time
The Rolex time change is done after three clicks when you pull the winder. If the winder can actually be pulled out of the stem (separate) the damage is serious.
Sorry. Only an authorized dealer can get the parts for it to be repaired.
Feb 03, 2014 | Rolex Oyster Perpetual Day-Date Watch...
I got a president day date rolex, sometime the date jump twice in 1 day
Reset the time, day and date manually from scratch. Check for another 24 hours. If the problem persists that means there is interference between day and date wheels and in this case you will need watchmakers help, as to correct such a fault the watch needs to be disassembled almost completely.
Feb 24, 2011 | Rolex Oyster Perpetual DayDate 18kt Yellow...
Jul 28, 2009 | Watches
How do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Apr 04, 2009 | Watches
I need an owner's manual for a Rolex Oyster Perpetual Day-Date. Any idea where I can locate one?
Mar 31, 2009 | Rolex Day-Date President 118238 Wristwatch
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Watches Logo
Top Rolex Watches Experts
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
