Philips SoHo 107T21 (White) 17" CRT Monitor Logo
Anonymous Posted on Nov 14, 2011
Please show me value for resistance location no are 3644 and 3626 in philips 107T , thanks for the help
  • 2 more comments
  • Brian Sullivan
    Brian Sullivan Nov 18, 2011
    what sort of problems are you having with your monitor
  • Anonymous Nov 18, 2011
    Hi, why have you sent me 12 requests for equipment which I do NOT support, please? I was dealing only with washing machines but I am going to cease completely now mainly because of being flooded with these rediculous 'direct questions'. Sorry. Good luck. John C
  • Steve Allison
    Steve Allison Nov 18, 2011
    The circuit reference numbers won't help much unless a factory tech happens to see your request. You need to describe the problem you are having and why the resistance values are not visible (burned?). There are methods of achieving a close estimate of the value of a burned component and the likelihood of anyone outside the factory having access to schematics is extremely remote. Also, you might try to determine in which circuit these resistors are located since that would also give us an idea of the value and power dissipation requirements.
Brian Sullivan
Level 3:
  • Philips Master 27,725 Answers
  • Posted on Nov 18, 2011
Brian Sullivan
Philips Master
Level 3:
Answers
27725
Questions
Helped
5668980
Points
79191
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
My 46" lcd keeps shutting
You have popped capacitors on your power supply.
Here is what you need to look for:
Once you locate the problem capacitors you will need to replace with the SAME uF value and HIGHER voltage value. EX: 1000uF 10v ---->1000uF 35v
Thank you and best of luck!
Please rate!
1helpful
We went to turn our TV on and when it turns on the Philips logo usually appears before it turns on. It is frozen on the Philips logo screen. You can't turn it off. And it will not go to the TV. I'v...
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
Please show me value for resistance location no are 3133 and 3407
hi,
The resistor 3407 is 1ohm 2W resistor
I have searched in the circuit for 3133, but i didn't find it . can you tell me in which section you have seen that resistor.
if you send me your email id through fixya will sent you the schematic diagram.
ok
5helpful
3answers
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
52 in philips help.
the large IC's on a big heat sink is where the convergence ic's will be
here is an example http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
the resistors will be on the lines of these IC's
need help identifying the resistor values?
2answers
Resister burnt
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks. [email protected]
Oct 02, 2008 • RCA DRC8335
Resisters questions
Its best to replace both IC's. As far as the resistors, there are location #'s marked on the board where the resistors are mounted. If any look burnt, get the location numbers off the board, and your model # and email me @ [email protected]. I will get you the resistor values.
Black screen
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
Resistance value
plz send model number of monitor
Top Philips Computers & Internet Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
