SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
SOURCE: heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
SOURCE: lower heating element stopped heating
sorry to here about your trouble ;i suspect the elemant is blown check your manaul some cookers can be reset but again you will have to checkyour manaul on how to do this sorry this time i cant be of more help,adrian
