When ever you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
F2 - E6 Cancel key drive line open
This is due to the control board not functioning properly as it should be. Either buy a new control board for your appliance or get it repaired.
I would personally recommend www.partsimple.com, since they have the replacement parts at lowest price and also repair service for faulty control board that too again lowest price compare to other online vendors.
TV parts Water Filter Washer parts Laptop Parts Replacement Parts...
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day.
