This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
The solution you have given is fine. But i asked Sony service center here in my town they said they can't do that. And Sony Customer Care says i can do it with some other private service centers if its done so the warranty of the product will be voided. How can i upload you the pics of the laptop n camcoder? I want you to have a look and say if firewire card can be fixed in this particular model. And i need atleast 1 USB port out of 3 for my internet data card and pen drive.Does such card exist ? 1 USB and 2 Firewire ports card or 1 USB and 2 Firewire ports
Capture card?? What do suggest on that? Can capture card do the job? Or if you could suggest some one who is capable of fixing firewire card in Bangalore, India?
Unfortunately your options are almost zero with this laptop,the Vaio VPCEG18FG is not equipped with an firewire socket or PCMCIA SLOT, you have to use a Firewire socket to get mini dv video onto your computer and nothing else and you cannot use a USB to Firewire cable or convertor as they are rubbish.
If your DV camera has analog outputs Composite or SVHS you could always capture using a USB capture device, your quality won't be as good as native DV but its pretty much your only option with that machine.
USB Video Capture Devices > http://www.tigerdirect.com/applications/...|c:1428|&Sort=4
Another option is to purchase a cheap laptop that has a Firewire socket /port/jack or a PCMCIA SLOT ..
I got it vEvO. I mean what u said. Now how to fix this Firewire card. Is anything like this in the given link can be used?
http://www.youtube.com/watch?v=eyd6HwHRB...
It could be a solution to purchase an usb to expresscard adapter and a firewire expresscard adapter..
http://www.amazon.com/StarTech-com-Expre...
http://www.amazon.com/SIIG-JU-EC0032-S1-...
You need to make sure that the USB Based Expresscard Adapter is compatible with the Firewire ExpressCard.
