Question about Razor E300 Scooter
Razor e300 needs to be continually reset
It is no longer working at all. It seems like it was brand new out of the box and that this problem existed.Any suggestions?
Sorry it is really important to get your scooter put together and charged right away or it will get ruined Need new batteries
Posted on Nov 27, 2011
SOURCE:
How do I get my Razor scooter to run? It has new batteries and smokes at fuse box when reset is pushed
If the batteries are connected correctly (red to +, black to -) then the motor is trashed
Jan 25, 2016 | Razor E300 Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
Wont start razor e300
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
Oct 02, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
Razor E300 runs but very slowly
get some new batteries.
yours are worn out.
Mar 29, 2013 | Razor E300 Scooter
How do you change the tube on the E300's rear tire?
Just buy a new rear wheel. The wheel is not meant to come apart without breaking a couple fingers in return. Besides the new tube is about 15 dollars add the shipping and for another 20 dollars you can get it brand new complete, wheel, tube, rim, axle. I'm not saying it can't be done but why put yourself through this.
Oct 04, 2010 | Razor E300 Scooter
Need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
May 14, 2010 | Razor E300 Scooter
Razor E300 Scooter Logo
380 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
