Question about Nokia 6300 Cellular Phone
Nokia 6300 wont turn on, blue lights on side stay on
Brand new phone appears to have locked up. Charged it up, but it still will not turn on and the blue lights on the side stay on and slowly blink. Ive pressed every concievable button combination, removed battery, sim, re- inserted and swore at it. nothing works
  • Anonymous Mar 20, 2009
    nokia 6300 wont turn on, blue lights on side stay on
    dont know what to d
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
Posted on Sep 28, 2008
SOURCE:
My phone wont go to my lock screen it keeps turning on over and over again
Try removing the battery, wait 30 seconds, and replace the battery.
Nov 04, 2014 | Boost Mobile Kyocera Hydro Smartphone
Tip
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
on Jan 27, 2010 | Cell Phones
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
My htc freestyle wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 05, 2012 | HTC Freestyle Smartphone
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Hi, I am facing problem in getting my new Nokia N97 recharged. When i turned my Mobile Off the charging light on left side appears very bright and Mobile gets charged properly. but when i turn it on and...
this issue is generated from some types of software problems, you need to get back to Nokia dealer and they will solve you the problem in a seconds
Aug 25, 2010 | Nokia N97 Cell Phone
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Still froze
Does the light blink blue other wise and show red when charging ?
Make sure ear set is fully charged overnite?
Turn off and turn on.
Only then when turning on, DONT REMOVE YOUR FINGERS AND KEEP PRESSED for about 10-30 Seconds,, Watch for SOLID BLUE... Remove and proceed to pair..
If it still does not work, I would suggest that you keep trying .. Since I assume that the phone is charging well and then discharging over a time..
Oct 29, 2008 | Motorola Mobility Logitech Mobile...
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Nokia 6300 Cellular Phone Logo
1,918 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
