A
Anonymous Posted on Nov 12, 2011
How to work to the 2nd and 3rd powers
Working algebra
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Office Equip... Master 102,366 Answers
  • Posted on Dec 21, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432233
Points
622693
Most calculators have a power key. It may be marked "^" or "x-superscript-y" or similar. This key can be used for any power, not just 2 and 3.
Many calculators also have a dedicated 2nd power key, typically marked "x-superscript-2". Some calculators also have a 3rd power key.
2000 larado won't shift from 2nd to 3rd
Hello. It seems your vehicle's transmission has to be rebuilt/replaced. Any automatic transmission that won't 'shift' from 1st gear into 2nd or 3rd gear has a 'worn' slave cylinder that 'slides' gears one way or another. 1st gear works yet 2nd and 3rd don't. Good luck and keep me informed; if you want to.
I have 2007 Chevy Uplander and it just stopped working in 3rd and drive all the other gears work?
If you only have 2nd gear then you likely have no power to the trans. If you ave no 3rd and 4th then the problem is internal.
1helpful
What is causing transmission to only work in 2nd and 3rd and reverse.? in 2nd and 3rd it feels like its trying to downshift into 1st. In 1st there is a little resistance but it doesnt move
How does your transmission fluid look and smell? If it is dark and smells a little burnt, the transmission is very likely toast. If it is still clear and red, you should let a transmission specialist diagnose it.
My transmission only has 2nd and 3rd gear and in order to get them I have to manually shift from 2nd into 3rd. My 1st does not work at all and neither does my overdrive. The computer is giving three...
The solenoid directs fluids to the governor and valve body( inside the ****** ). Better bring that to the nearest garage to check the fluid and the filter, just to see if fluids flows freely. The solenoid can be check by applying power just to see if it still works.
Hope that helps you out!
I need to know how to use a scientific calculator to calculate Euler's number for an algebra problem. IE: 5000e to the 0.96th power
5 0 0 0 2ND [e^x] . 9 6 ENTER
computes 5000 e^.96
If you want (5000e)^.96 then it's
( 5 0 0 0 2ND [e^x] 1 ) ^ . 9 6
e^x is just to the left of the 4 key.
11helpful
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
2helpful
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
[email protected]
k24674
