Dryers Logo
Posted on Sep 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The tumble dryer bip and flash "empty water" even if no water. I have cleaned every filter (2 inside the big filter at the bottom of the tumble dryer) but still have the trouble
  • 2 more comments
  • hennequl Sep 27, 2008
    the tumble dryer is LG TD700 CE
  • hennequl Sep 28, 2008
    after removing water at the bottom behind filter it is working for a little while but the water comes back.
    I have checked both flexible pipes and they are not blocked ... it's looked like the pump is not working ...
    what should I try now?
  • hennequl Sep 29, 2008
    every thing has been cleaned even the fan at the back but still no water comming into the water tank at the top but a lot of water at the bottom.
    I checked the drain too ...
    the model is LG TD C 700 E and I bought it 2.5 years ago.
Anonymous
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Sep 27, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
208
Questions
Helped
119506
Points
604
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
the tumble dryer bip and - 8d2299a.jpgble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3088605
Points
19604
Your exact model is not available in my region, however. most LG dryers have a water collector bottle/container at the top end of the unit. If you unit has such a component, might it be that this is the one that needs emptying? Additionally, there is a pump/sump at the very bottom of the unit. Normally this is where the sensor is that triggers the alarm/indicator "empty water". It could be that the sump is full of water or it is simply very damp in that area that the sensors are reading wrong. It is not a filter problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 1 more comment
  • Anonymous Sep 28, 2008
    Hi again,
    For some reason, I could not find any technical documentation for your model, the LG TD700 CE. Related to this a couple of ideas:
        pls verify model at the name plate/tag at the rear of the unit (some LGs are actually rebranded Zenith or GoldStar products);
        pls post back whether the unit is pure electric or combo gas/electric;
        pls post back your general location.
        Incidentally, there is normally a reset button at the rear (sometimes at the bottom) of most dryers, pls try this or unplug for about half an hour.
    Additionally, you may want to check:
        moisture sensor, try removing one of the connectors and making sure it is not touching any metal part of the dryer. This should make the "empty water" not to come on. On the other hand, shorting/jumping the two connectors should make the "empty water" to come on and/or run the bottom pump;
        thermistor or thermal cutoff. This is inline with the wiring of the pump motor, if this is open, the pump will not run. A test is to short/jumper the two connector of the thermistor or thermal cutoff. If the control board and pump are OK, then the motor should run, removing the jumper should make the pump stop;
        pump motor, checking for the supply voltage;
        control board, visually inspect for any burnt marks, cold solder or anything out of the ordinary.
    This of course would require familiarity of electrical components/circuitry, safe procedures when working with electrical/live appliances and use of a DVM (or a continuity tester/voltmeter). It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
  • Anonymous Sep 29, 2008
    Appreciate your post/comment back. Based on this, the model is TD-C700E, most likely marketed in Australia and it is a 7kg Condensor Dryer. And as initially posted, you would need a continuity tester to check the components with particular attention to the thermistor, water sensor and drain pump,
    Incidentally, perhaps it would be more convenient for your need to either:
        get hold of a service manual that would illustrate checkpoints and pictorial diagram; or
        consult:
        LG Australia Service Centers
        BigWarehouse Spares ACN: 31 119 434 847 Australia, Fax: (02)80808122, or click here.
    For some reason the links do not work, pls try again
        BigWarehouse Spares ACN: 31 119 434 847 Australia, Fax: (02)80808122, or click their "Contact Us".
Anonymous
Level 3:
Genius:
  • Master 1,142 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1142
Questions
6
Helped
444293
Points
3128
Please provide the correct model number which will help us to get you the correct solution.
1helpful
Bush td7cnbcw tumble dryer, always worked perfectly. Only trying to turn it on the morning and the 3 and 9 hrs lights started flashing after 3 turns. Anyone know what this means?
The flashing lights on your Bush TD7CNBCW tumble dryer could indicate an error or fault in the machine. While I don't have access to specific error codes for this particular model, I can provide some general troubleshooting steps that may help you identify and resolve the issue:
1. Check the user manual: Refer to the user manual that came with your tumble dryer. It should contain information about error codes and their meanings. Look for any reference to the flashing lights you are seeing.
2. Power cycle the dryer: Turn off the dryer and unplug it from the power source. Wait for a few minutes, then plug it back in and try turning it on again. Sometimes, power cycling can help reset the machine and clear minor glitches.
3. Check the door switch: Ensure that the door of the tumble dryer is fully closed and latched. The machine may not start if the door switch is not engaged properly.
4. Clear any obstructions: Make sure the drum inside the dryer can spin freely and is not obstructed by any items or lint buildup. Clear out any debris or lint that may be blocking the drum or the lint filter.
5. Check the water tank and filter: If your tumble dryer has a water tank or condenser unit, ensure that it is empty and clean. Additionally, clean the lint filter to ensure it is not clogged, as this can affect the dryer's performance.
6. Consult customer support: If the issue persists and you cannot find a resolution in the user manual, it is recommended to contact the Bush customer support or a qualified technician who can provide specific guidance and assistance for your model.
Remember, safety should always be a priority when dealing with electrical appliances. If you're unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek professional help to avoid any risks or further damage to the appliance.
May 26, 2023 • Dryers
My tumble dryer keeps stopping after approx 2 mins The container light comes on.
Hi.
You have clogged waterways for condensed water.
You have to clean this.
Nov 28, 2017 • Neff Dryers
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
1helpful
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
My Hotpoint Aquarius TCM580 tumble dryer has the "Empty Water" alarm in constantly despite the water container being empty. When the "Empty Water" indicator lights, the heat is turned...
I had this issue and the answer above about tipping your dryer / cleaning the condenser worked a treat for me. So thank you to whoever posted it. And don't forget to clean your filter, bottom front, regularly. I keep forgetting this and am sure it probably contributed to the problem.
Jun 22, 2011 • Dryers
3helpful
I need to clean my filter on my beko tumble dryer!
I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
Feb 23, 2010 • Dryers
10helpful
2answers
11helpful
3answers
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 • Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 • Dryers
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
