Sewing Machines Logo
lisa Hoyles Posted on Sep 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble sewing lycra fabric using a zig zag stitch
I have a kenmore 18 stitch sewing machine model 385-1664180. I am having trouble sewing lycra fabric using a zig zag stitch. The machine is set correctly for zig zag, the needle moves back and forth but it wil sew 1 zig zag stitch and then a series of straight stitches then another zig zag etc. Please help. Sewing dance costumes. Any suggestions? Many thnaks Lisa
Chance Miller
Level 2:
Sergeant:
  • Sewing Machines Expert 455 Answers
  • Posted on Sep 20, 2017
Chance Miller
Level 2:
Sergeant:
Answers
455
Questions
Helped
113634
Points
904
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
5 Related Answers
Rommel Balcita
  • 749 Answers
  • Posted on Nov 02, 2007
SOURCE: upside down stitching
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
A
Anonymous
  • Posted on Jan 24, 2008
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Anonymous
  • Posted on Apr 08, 2008
SOURCE: my zig zag is not working properly
no i have not received an answer to the problem from no one
neither anyone having a repair book on this machine, anyway the reason i cannot purchase a plan is because i dont have a crdit card.
Anonymous
  • 323 Answers
  • Posted on May 22, 2008
SOURCE: forgot how to set stitch
Find your zig zag width control and set it at 0 You will have a straight stitch.
sewman7
Anonymous
  • 1027 Answers
  • Posted on Jul 10, 2008
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
What stitch should I use to sew stretch cotton fabric
Stretch cotton fabric? Use a ball point needle and probably a zig-zag stitch. The more stretchy the fabric, the wider the stitch and the shorter stitch length between the zig-zags. If the thread is popping when you stretch the seam, then widen the zig-zag and shorten the stitch length.
How can I stitch Stretchable cloth with this machine..
Be sure you are using the correct needle for stretch fabric.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjmkeKwzpbOAhVPVWMKHVBjAAQQFgg3MAQ&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Set your machine for a zig-zag (or stretch stitch if you have it) to accommodate the fabric stretch.
Use a good quality thread. Avoid old or bargain bin threads. Cotton thread will break easier than polyester.
You may need to adjust the tension for the fabric.
How to Sew Knits and Stretch Fabrics with Sewing Machine
3 Things To Know Before Sewing With Lycra SewsNBows
Sewing Spandex Tips
I would like to know what stitch number to put my sewing machine onto to stitch stretch material. I have a Elna 40 sewing machine regards Judy
Looks like stitch #06 might be a stretch stitch. You could probably also use a slight 08 or 09 zig-zag. Unless you are sewing something really stretchy (lycra) IMHO, a slight zig-zag is fine and actually is a lot faster than a stretch stitch which takes a few stitches forward and then one or two stitches in reverse. The stitch #09 is something that I use frequently for stretch fabrics.
Elina 40 Question and Answers
1helpful
2answers
2answers
I dont have the instruction manual and i cant figure out how to do a zig zag stitch? Help
You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
Raw edge zig zag stitch bunching underneath
When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
My new Singer machine ("Curvy") purchased last week (3/2014) has a page on stretch stitches. The way the book is written, it lists Straight Stretch Stitch on the same page as Ric Rac, HOneycomb, and...
A zig-zag is also a stretch stitch. Usually, a "built-in" stretch stitch will stitch forward a couple and then stitch backward and then stitch forward again (time consuming and uses a lot of thread--but suitable if that's what you want). Whatever you are sewing, whether it is a seam or finished raw edge and the fabric is stretch, you will need to use a stretch or zig-zag. A straight stitch will pop the threads as soon as the fabric has to give.
You can test your stitches on some scrap fabric and see what looks best.
An Over-edge stitch is just that, just a stitch over the fabric edge. It probably would not be suitable for sewing a seam.
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
2answers
What would be a "stretch" stitch setting?
For a stretch stitch use a narrow zig zag stitch. Use a ball point needle with knit fabrics.
My machine sews straight when set to zig zag and skips stitches sometimes. It zig zags but only gets half the stitch.
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
