Brother HL 5250DN Laser Printer Logo
J. C. Posted on Nov 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother HL-5250DN paper light fashing
The paper light flashes on and off and the red Status light is steady on when I turn on this Brother HL-5250DN laser printer. I obviously load the paper cassette with letter size paper and even I put also paper on the manual tray. but the printer still won't recognize there is paper loaded in their trays. To me it seems like the paper tray itself when it is all the way in, the mechanism doesn't lifth the paper at all from the paper cassette, I manually tried to bypass all the sensors that make contact with the paper cassette when it is in the printer, but that doesn't make any difference. Do you think that one of more of the sensors are bad? Thank you for yours suggestions.
Tareq Bin Mostaq
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jun 06, 2019
Tareq Bin Mostaq
Expert
Level 2:
Champion:
Answers
205
Questions
5
Helped
112324
Points
323
Disconnect all usb cable from computer .power off again power on
press & hold down go button press t times if print , reset printer drive in your computer or not print test page replace drum unit .
  • Gordon
    Gordon Apr 18, 2022
    Also take the toner cartridges out as there maybe paper stuck in the printer.
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Dec 07, 2007
SOURCE: paper jam light won't turn off!
see my post
http://www.fixya.com/support/t262880-paper_light_constantly_flashes
Anonymous
  • Posted on Jan 02, 2009
SOURCE: brother HL-2040 laser printer
brother laserjet HL2040 printer
tonner error / paper error / continued rolling
what is the problem
Anonymous
  • Posted on Apr 06, 2009
SOURCE: I want to find the MAC address on a Brother
Go to Printers and Faxes.
Right click on the printer and select Properties.
Toward the bottom, click on Printing Preferences...
Click on the Support tab.
Click on Print Settings.
This should give you three pages. The third page has the network settings including Ethernet/MAC address.
Anonymous
  • Posted on Apr 29, 2009
SOURCE: HL-5140 Brother laser printer red status light remains on.
Help me, please . Red status light on. PC recognises printer. Nothing happening. Toner was on for a few weeks. But now new toner cartridge and still solid red light. What is this?
Anonymous
  • Posted on May 14, 2009
SOURCE: Brother HL 5170DN Laser
I had same problem, I removed the duplex unit, removed the back and found that the fusor unit rollers had become unclipped where someone had pulled a jam out the back of the unit
6helpful
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
2helpful
All led lights are flashing and red light on status
Press and hold the GO and Cancel buttons together, the lights should then change to just the status and either the toner drum or paper light on. Depending on the lights that are displayed will determine what the actual fault is.
Let me know what you find as this will help diagnose the actual fault.
7helpful
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Hi - I have a Brother HL5250DN with the paper light flashing but there is paper in the tray and now it wont print - can you help??
Is the Status light also red? This could mean other things than being out of paper. It could be a paper jam (most commonly anyway). Get a flashlight out and inspect it for jams.
2answers
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
3helpful
2answers
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Brother HL5250DN red status light, no printing even with driver reinstall
I had this exact same problem
I just had mine repaired at an authorized Brother service center...It was the "Main PCB Assy". or the "main board. Total cost with tax....$100.
I'll try another brand before I buy Brother again.
Norman Weimar
Norman Weimar
k24674
