You will be needing to disassemble the whole rear door or lid. Inside you may find a plastic part broken. You should find a lot of plastic clips holding it all together, which clips will break when you start to take the door apart. Which clips may be very hard to find replacements, unless you go to Hyundai. Be blessed.
I believe you're referring to the lid safety switch. Do not operate your machine without this safety switch! The switch / wiring harness are not very hard to install... here's how-
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET--- 1. Remove console, depending on vintage, there should be a couple of screws that will allow you to rotate the console up and back. 2. Remove 2 gold clips at rear of top. These clips are the only thing that retain the top / lid / cabinet 3. Unplug lid switch harness (small white connector at rear of top) 4. Rotate the cabinet up a few inches at the rear and pull it straight off. The top / lid / cabinet will come off as a single unit. The entire lid switch and harness are connected under the top w/ a couple of screws and a few spring retainers. 5. Buy replacement parts at a local appliance repair shop, including a new striker (the part that pushes the switch down when you close the lid). 6. Reinstall everything reverse from above. When you rotate the cabinet back on, make sure you have the front edge under the base channel and push inward on the rear corners to engage the cabinet on the rear base tabs.
Check your lid switch.. If it stops at the spin cycle and will not drain or spin, it is possible that the switch is broken. There is a small tab on the lid that activated the lid switch lever..
See if you can see the plunger and look for the corresponding hole
that it would go into on the top, and there is your lid switch. The
purpose of the switch is to stop the tub from spinning when you open the
lid during spin cycle. Broken switch equates to no spin or drain
however even with the lid closed. Here are some basic instructions:
Accessing
this part requires you to first flip up the control panel by: Removing
two phillips head screws in the front bottom corners of the control
panel, or the rear lower corners of the control panel. *NOTE for some Kenmore models it may be necessary to remove the endcap covers to expose the screws on the front of the console* The most recent designs have spring clips under
the left and right sides of the control panel that need to be depressed
with a putty knife to release them. Pull the panel forward and lift to
disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next
you will see one wire connector going into the top of the machine, this
is actually your lid switch connector, disconnect it (all the rest of
the wires will route behind the top of the machine, between the top and
the rear panel). Now using a flat blade screwdriver pry the front of
the two brass colored clips towards the rear of the washer (put tip of
screwdriver into front most part of clip and press handle of screwdriver
towards rear of machine). The clips should pop off the top pretty
easily. Now you can open the lid and place a hand on the front of
the opening and pull the cabinet forward. The entire front and side
wrapper will come off the base platform and you can set it on the floor
to gain access to the inside of the cabinet where the lid switch is mounted and the wires are routed.
Sounds like your lid switch is broken if it will not spin or drain out..
Here are some step by step instructions, They seem daunting, but what do you have to loose by trying yourself?
Depending on your model there are a couple different varieties, but the
most common one was a switch activated by a plunger on the side of the
lid. See if you can see the plunger and look for the corresponding hole
Accessing
Next
kds e2 means lid switch is not being engaged .remove rear top cover .2 phillips screws .3 snap clips use flat blade screw driver to pop cover .look at rear of lid (door) right side plastic arm part of lid snaped off replace lid part xqb5526f.1.3-3 check saftey switch manually over ride switch as a test .if machine spins change lid if switch broken as well change both .switch # xqb550.1.6
Sounds like your lid switch is broken.
This is located under the top of the washer and is activated by a tab
that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by
removing two phillips head screws in either the front bottom corners
(may be behind the end-cap covers), or
rear bottom corners, pull panel forward and lift to disengage the tabs
at
way. Next you will see one wire connector going into the top of the
machine, this is actually your lid switch connector, disconnect it. Now
using a flat screwdriver pry the front of the two brass clips towards
the rear of the washer (put tip of screwdriver into front most part of
clip and press handle of screwdriver towards rear of machine). The clips
should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening
and pull the cabinet forward. The entire front and side wrapper will
come off the base platform and you can set it on the floor to gain
access to the lid switch that is screwed to the underside.
Good luck to you on this!
at
removing two phillips head screws in either the front bottom corners (may be behind the endcap covers), or
rear bottom corners, pull panel forward and lift to disengage the tabs at
Remove the two screws in the top of the console they will be in the rear left and right side or in the front corners then flip up the console and remove the 2 spring clips (brass)and the lid switch molex plug the cabniet will come off tilt forward and pull out you will see the lid switch running on the underside
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
