Hilti TE 7-C 120V Rotary Hammer Drill Logo
ROBERT P LOUT Posted on Nov 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I straighten a chuck bend off removing a jammed bit?
Bit jammed in concrete and I bent it and the chuck/shaft removing it.
Anonymous
Level 2:
Scholar:
  • Hilti Expert 123 Answers
  • Posted on Nov 11, 2011
Anonymous
Hilti Expert
Level 2:
Scholar:
Answers
123
Questions
Helped
123221
Points
193
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Ryobi DP101 bench drill press chuck is off by 1/4". How do I remove the chuck? Could it be something else causing the rotation to be so way off?
yes, a bent arbor could be causing this... sometimes they can be straightened... or by a new arbor
For a Shwinn Joyrider PR150 double kids trailer Bent connecting shaft for front wheel to stroller, within front wheel assembly. I disassembled the front wheel assembly and straightened the bent...
Depending on how old it is, I would send it back on warranty. Do not keep bending it or it will break when you bend it, or worse, while in use. It might just be better to get a new, more durable stroller all together.
Bosch Hammer drill. When drilling, the bit hit a rebar and feels like it permanently warped the chuck. Is this possible, or did the motor shaft bend? the motor runs fine, but the bit does not run...
I would say that the motor shaft is probably bent and will need replaced.there are bosch service centers all over unfortunatly the price of parts especieally if it is a older unit can be almost what the unit costs.Sorry I'm not more help as I have several bosch tools in my shop and they are top quality tools. However I also have an old 65# electric breaker out there that is gathering dust because it has a cracked armature and the parts alone to fix it are in excess of $800.00. Best of luck to you and thanks.
Apr 18, 2011 • Garden
I dont have the manel and need to no how to use it
The drill uses bits with the SDS+ connection end. You have three different modes of operation. Hammer drill for drilling into concrete. Drill only for drilling into wood or steel and chip only for chiseling concrete. Now for drill only you would have to change out the chuck for a jacolbs style.
The bits just snap in the chuck. To remove the bits you just slide the chuck sleeve back and remove the bit. To change the chuck you wolulld place the palm of your hand over the chuck and using your fingers pull the sleeve on the chuck that is near the red housing towards your palm and just pull off the chuck.It will snap back on the same way.
1helpful
2answers
My carriage on my Janome 350E is jammed and is not moving properly
See if the embroidery arm is bent, that will jam the unit as it trys to move. If is bent you may be able to straighten my bending it gently. The arms get bent by tilting the machine to the back while the arm is exrended.
1helpful
2answers
I can't get the bit out of the breaker
Sounds like the bit bent slightly and as a result jammed into the chuck. Open chuck as much as possible and have someone pull the bit out while your tapping it with a small hammer. The vibration from the tapping might loosen the bit from the chuck.
2answers
Broken Makita Drill 6408k chuck
separate the housing and remove the gear assembly and chuck ....see if you can use a open end wrench on the shaft and locking pliers on the chuck body
3helpful
2answers
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 • Skil Drills
2answers
Cordless drill- chuck jammed.Model No. HP146F2B
b&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
Top Hilti Drills Experts
Paul Bade
Ngoro
john h
Are you a Hilti Drill Expert? Answer questions, earn points and help others
