LG 42LC2D 42 in. LCD HDTV Logo
Jake Posted on Nov 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant tune any channels
Tv saying programme list empty and cant find any when auto tune
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 118 Answers
  • Posted on Nov 29, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
118
Questions
0
Helped
21682
Points
269
Check and make sure you have correct input selected ( ie cable, antenna)
thanks Tom
Hi my channel list is empty please assist
You must auto tune the TV so it knows which channels it can receive and which it gets no data from. The menu should have this setting. Make sure your cable box or antenna is hooked up to the TV before you begin the auto tune. Also be aware that an antenna will no longer receive analog broadcasts due to the digital switch in 2009.
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
1helpful
2answers
Hello .i have a lg tv which i purchased in 2008 and only watched videos,i now want to watch tv i have tried auto tune and it only finds 3 vhf channels and none digital.it has preview built in but i can not...
if it has freeview built in its usually programmes itself try turning it on and go into the menu and there should be an auto tune function hit that and it should tune up but remember it needs to be connected to an aerial if it still says no signal try moving the aerial, getting a booster for the aerial they usually plug into the mains then into the back of your tv and you plug your aerial into that to boost the frequencey if that doesn't work then you might need to think about getting a new aerial but you can get 1 for under £30
LG model NR CI-14F80FS Moved the TV for an elderly person,using the remote, how do I start the automatic re-tuning [email protected]
By pressing menu botton on remote then chose setup/then channel setup before presssing auto tune or channell auto programm you may choose air or cable option then you can go for channel auto programming and your supposed to be done.
hope that will help you
have a nice day
regards alan
I now cant get bbc 1,2 ,3, on my free view box it wont tune in
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Cant get all channels
Instead of doing auto scan the should be a option for channel list or add\delete or manual scan. What kind of tv is it? You don't have a cable box right? If you still have trouble, just comment on this.
2answers
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
