SOURCE: Fuel line for Stihl 025 chainsaw
Hi
It happens sometimes.You have to replace the fuel line.This is a trick.Remove the gas tank cap and take off the fuel line and remove the fuel filter.Take off the fuel line from the gas tank.Cut off the piece of the fuel line wich is larger and seals the gas tank.Now through that piece of fuel put an ordinary fuel but about the same diameter.Put all back and that is all you have to do.If you need farther info just let me know. best regards savumihai71
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
SOURCE: stihl 025 diagram of parts needed.
Try to get an IPL here:
Stihl USA Contact Us
http://www.stihlusa.com/contact.php
Stihl considers all OE parts, IPLs and Shop manuals proprietary. When they discover an on-line source for any of these they force it be removed. If they tell you no your recourse is to register a complaint. Please do. Then go here, join, post an email address and your need.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: I need to rebuild the carburetor on a Stihl model
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
