JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
wade burke Posted on Nov 10, 2011
What do i set my computer to so i can watch it on this tv
How set up TV given by friend not using anymore? Don't want to use as computer...just TV.
If it is an LCD monitor it will not have any cable input or components to watch TV. Look behind the monitor to see if there is any cable input if it does have it than you can watch TV if not you will need a computer.
Want to know how to watch Netflix on TV
Connect your computer to your TV via hdmi cable. Go to control panel, display, settings on your computer to complete your connection. If you haven't allready subscribe to Neflix and you're watching movies 24/7. Might I recommend Hulu.com and tvweb360.tv, they're free!
1helpful
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
1helpful
I have a computer that has a cable connector on the back and when i try to watch tv from i only have from channel 3-13 when all my other tv's have to at least 65 how do i set this up?
Whatever software you are using on that computer to watch TV, make sure its set to cable and also have it do a search for all the channels. At that point it should find all the channels up to 65. If it still doesn't then it could be a problem with the cable connector on the computer but I would first hook up the wire to a regular tv to make sure it is indeed able to go up to 65 so you know for sure.
2answers
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
2answers
SPLIT SCREEN ON 50'' PLASMA
If you talking about on one screen, you cant. BUT you can buy a TV card for your computer so that it will have a built in TV. so you can theoretically have split screen TV and computer. But what your thinking off only works on 2 or more player games consoles
Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
Blue Box in the Corner won't turn off!
That problem might be on the remote of display settings on video display. There is one button that will turn that off. Try Display Settings
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
