Question about LG LRMM1430 Microwave Oven
How to turn off annoying beep sounds of alert and programming
This is not LG LRMM specific but rather a general question relating to microwaves. I have long resisted getting a microwave, initially because of rumored microwave leakage/dangers but laterally because of an increased annoyance listening to the irritating beeping they make when setting the timer and then again when the food is ready. Is it relatively easy to disengage the beeper without compromising the functioning of the unit itself?
  • Anonymous Oct 29, 2008
    My LG Microwave a 2000 model do the same thing .. BEEP BEEP BEEP like a murder is commited in my kitchen once the cooking cycle is finish and this for hours ... until some one open the door. I think seriuosly to unplug the beeper of stuff-it with glue ....
  • LG Master
  • 9,174 Answers
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
Posted on Sep 28, 2008
SOURCE:
GE JES1344SK01 microwave: turn off reminder beeps
I checked my GE micro information and nothing is said about disabling that annoying beep. Guess GE feels it is for your own good, like a noisome nanny.
Jan 02, 2014 | GE JES1344SK Microwave Oven
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
The only way to stop the beeping is to push the cancel button then immediately open the door. This is the only microwave Ive ever encountered that doesn't stop the beeping when you either open the door or push the cancel button. To make it even more irritating, the beeps are VERY loud and long. Here is a short you tube video posted by someone who recorded this loud and long beeping I am referring to. https://youtu.be/pDq7LTpPNTY
Aug 19, 2012 | Frigidaire Microwave Ovens
How do I stop the beep when food is ready (it beeps if you don't remove at the food after intervals)? Sharp R-340
I too have Sharp microwave that constantly beeps at approximately one minute intervals if the food you have been heating isn't removed. It is loud, persistent and extremely annoying. I've opened the machine to try and find the loud speaker but cannot find it (it could be built in to the circuitry?). Any help on this would be appreciated. It's a very unfortunate design flaw on what is otherwise a very good and easy to use microwave.
Jun 10, 2010 | Sharp R-340 Microwave Oven
Oven does not heat and makes loud, continuous "hum" when turned on and related to turning of oven table.
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Apr 26, 2009 | LG Over-the-Range Microwave
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
LG LRMM1430 Microwave Oven Logo
5,044 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
