The left outer spinder gear and the top spider gear , the cogs have worn ? not meshing right ?
You do not even need a dial indicator to set the backlash.
Just make sure you put the side shims back in on the same side they came out of.
Remove your ring gear from the your carrier.
Remove the ring gear from the carrier from the other truck and put your ring gear on it.
Torque the bolts with thread locker on them.
To get your carrier out:
Loosen the the two bolts at each top corner and remove all the rest of the bolts from the cover.
Put a pan under it and brake the seal and let it drain into the pan and when its done take the cover off.
Remove the wheels and drums.
Remove the pinion pin retaining bolt.
Remove the pinion pin.
Push both axles in.
Remove both "U" retainers from the axles.
Pull both axles out.
Remove the bearing retaining bolts and caps.
Mark the shims so you can put them back in on the side they came out of.
Pry the carrier out with a block of wood at the mating surface of the cover so you do not hurt it with the pry bar.
Put the LS carrier in and drive your shims back in on the side they came out of.
Install the bearing caps and bolts and torque to what is called for.
Push the axles back in and put the "U" retainers on them.
Put every thing else back to in place.
Use RTV for a gasket on the back cover.
Put some LS friction modifier in the rear end and then fill it.
My notes:
Things I have learned about 8.8 Rear Ends that were set up by the FORD FACTORY and not touched by anybody.
Well i hope this helps.
