Hi
You do not actually say if you have ever had the card working in the
Kodak EasyShare C190 but if the card has worked in the past and is now giving the error it could be down to corruption.
Flash memory cards can become corrupted for a number of reasons - the most common being:
1. the card is removed whilst the camera is still reading or writing to it
2. the power fails when the card is being written to or read from.
Corruption can sometimes be fixed by re-formating the card using a USB card reader attached to a computer. Most cameras will provide a re-format option (which sounds as if you have tried) but all this format does it to relay the directory structure on the card - if the card is corrupted this will not be solved.
Formatting the card in the USB reader will wipe the card of all data - NOTE, any images that were on the card will be lost forever.
If this does not solve the issue I would suggest you try another card to narrow down the fault to the card or the camera itself.
I hope this helps to solve your problem
David
