https://www.mazdabg.com > Mazda6 > English
PDF
This manual contains on-vehicle service and diagnosis for the Mazda6. For proper repair and maintenance, a thorough familiarization with this manual is ...
Question edited for full 'year make model' in that order.
Question moved to correct category.
Service manual in the link, but for your electrical problem, you will need a mobile auto electrician with a pro grade scan tool computer to diagnose the issue.
You will require service manual for car, or the repair manual. Usually available at auto parts stores. Diagrams can be found on the web user browser search engine and " 1996 Mazda 323 Engine Fuel system diagram"
repair manuals for newer vehicles are rarely available for free online. Paper manuals are available for purchase in auto parts stores.
Google 'repair manual for 2010 Mazda 2'
Good luck.
The Mazda T3500 truck requires a specific torque for its bolts. According to [1], it requires a torque of 60 pounds for the first stage, 70 pounds for the second stage, and 80 FT Pounds for the final stage. Additionally, in [2], it is recommended to refer to the STANDARD BOLT AND NUT TIGHTENING TORQUE in Section TD for tightening torques which are not mentioned in the main text. Furthermore, [3] suggests that one should check the oscillation torque of the connecting rod. If the large end does not drop by its own weight, it is important to replace the piston, connecting rod, and/or piston pin.
**References:**
[1] [Torque specs for Mazda T3500 truck - Fixya](https://www.fixya.com/cars/t18472768-torque_specs_mazda_t3500_truck)
