Video Game Consoles & Games Logo
Melinda Cornelison Posted on Nov 10, 2011
I already have the Sims 3 installed and by mistake bought the Sims 3 plus pets and I meant to just buy the Sims pets expansion pack. There was a little book in it that has two registration codes, one
I alrady have the Sims 3, I just wanted to buy the Sims 3 Pets expansion Pack but I accidentley bought The Sims 3 Plus Pets and they have two codes, one for The Sims 3 and one for the Sims 3 Pets. Ityped the code for the Sims 3 Pets and it said it was invalid:( HELP
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3143
Points
There is an insert included inside the case that says 'EXCLUSIVE Limited Edition Content!' Use the code on this to install your game.
tip
Solve Installer issues
Many have been having an issue when installing the SIMS2 PETS expansion pack (EP) and Glamour Life EP.  The best way to resolve this is:
1. BACK UP your game folder first (usually: users + your folder + Documents + EA Games).  You want to back up the EA folder.
2. Download (do not install yet) the SIMS2 COMBO UPDATE patch at http://www.macupdate.com/info.php/id/18988
3. If you have already had the issue (which you probably did, otherwise you would not be reading this), delete your SIMS 2 folder from the HD and the EA games folder from the location mentioned above.  Yes, I know, it is painful but you saved what you needed, so stay with me.
4. Reinstall your SIMS 2 game (the base game).  Run it and make sure it works fine.  This will create a new EA Games folder where the old one was.
5. Now install the PETS expansion pack. If you want, start it to make sure it works fine.  All should be OK.
6. Now run the Combo pack. It will scan your HD to find the SIMS folder and what you need.  A window will open allowing you to select the install. Do it and install it.  If you click the arrow next to the installer options you will see there are patches for all the EP's, but they will be grayed except for the one you need.
7. Install your next expansion pack and run the combo patch installer again, now selecting the appropriate pack to patch.  Again, all others will be grayed except for the one you need.
8. Keep doing this with every expansion you install thereafter.  What the patch does is it updates each expansion pack to make sure it works by solving issues that came up after the release and will update everything up to December 2007.
9. After you are done, copy your original saved EA Games folder back into the location you had it.  You will need to hit 'replace' as SIMS will have installed a new EA Games folder in its place.  It is OK, this is all your games saved data.
10. Start SIMS2 and go look for your saved game!
1helpful
Sims 3 pets serial code is invalid
You probably just typed it in wrong. O's look like 0's(zeros), B's look like 8's... Did you put in the dashes, or leave them out... Try it both ways. Good Luck!
4helpful
SIMS 2 UNIVERSITY INSTALLED BUT NOT LOADING UP, NOTICED PEOPLE HAVING SIMILAR PROBLEMS. MY OTHER SIMS 2 GAMES ARE PC DVD ROM SIMS TWO UNIVERSITY I BOUGHT IS A PC CD ROM IS THAT THE PROBLEM WHY IT WONT...
I think university is the first or second expansion pack. I know there are issues if the expansions are not installed in order of their release. if you have say, seasons or freetime and then install university, it may not run correctly. You have to uninstall the packs or the game and re-install them in correct order. Yes, it's a big pain but I had to do it twice.
Install the SIMS2, or double deluxe whatever you have then follow this order with exception of say nightlife if you have have double deluxe because it comes with the original game.
The Sims 2" Expansion Pack Order
  • "The Sims 2 University"
  • "The Sims 2 Nightlife" included in double deluxe
  • "The Sims 2 Holiday Party Pack" (A Stuff Pack)
  • "The Sims 2 Open for Business"
  • "The Sims 2 Family Fun" (A Stuff Pack)
  • "The Sims 2 Glamour Life" (A Stuff Pack)
  • "The Sims 2 Pets"
  • "The Sims 2 Happy Holiday" (A Stuff Pack)
  • "The Sims 2 Seasons"
  • "The Sims 2 Celebration" (A Stuff Pack) also in double deluxe
  • "The Sims 2 H&M" (A Stuff Pack)
  • "The Sims 2 Bon Voyage"
  • "The Sims 2 Teen Style" (A Stuff Pack)
  • "The Sims 2 Free Time"
  • "The Sims 2 Kitchen and Bath Interior Design" (A Stuff Pack)
  • "The SIms 2 Ikea Home" (A Stuff Pack)
  • "The Sims 2 Apartment Life"
  • "The Sims 2 Mansion and Garden" (A Stuff Pack)
1helpful
My game, The Sims 2 Double Deluxe has what you call a bug in it that did not appear until one day when I was playing because we had all the expansion packs and the pets disappeared from the game and I went...
After installing Double Deluxe install the expansions you have in this order...
  • "The Sims 2 Pets"
your problem may be a graphics card issue. Did it work with the expansion packs or start problems when you installed the expansions?
maybe this link will be helpful if the above does not work.
http://thesims2.ea.com/help/detail.php?help_id=281
3answers
I ininstalled sims2/double deluxe because I didn't want it because I got the sims2pets. but I found out I have to have the sims 2 double deluxe to install the sims2pets. When I enter the installation code...
Make sure there is no sims 2 content on your hard drive. if there are any EA folders on your comouter either in program files or in "my documents" delete them. Then try installing Double Deluxe again. Then you can install pets.
Pets is an expansion pack for the Sims 2 base game. Other expansion packs are University, Seasons, Free Time, Bon Voyage.Open for buisiness and Apartment Life...If you plan to get other expansion packs you should install them in order of their release to avoid future problems. Nightlife expansion is included with Double Deluxe.
A simple google search for sims 2 expansion packs will show you the correct order to install and descriptions of each pack and what they add to the game. Seasons lets your sims go fishing for example. They can cook the fish they catch, and also plant gardens, and experience the changing seasons from summer to winter.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
