Lionel The Polar Express Train Set Logo
penny Chase Posted on Nov 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is the locomotive sparking while going on the track
While the train is running on the track every once in a while the locomotive sparks on the track.
non sequiter
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Jan 23, 2013
non sequiter
Expert
Level 2:
New Friend:
Answers
161
Questions
0
Helped
56016
Points
249
Sparky's is a common nickname & one
of the joys of our track powered trains.
Clean your wheels and track, it will help
lessen the sparking. Also make sure
your track is level without gaps
between the track sections.
hope this helps.
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Nov 10, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
20308
Points
269
The train gets it's power from the track. the spark, as long as it is small, is normal. it just means the wheels left the track for a second
Will the Lionel lion chief remote work with the Thomas and friends train and transformer?
Thomas & Friends Diesel Locomotive with LionChief Remote System ... LionChief locomotives can also run on any track powered by a conventional transformer ...
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
2answers
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 • Toys
My 2-8-4 Locomotive stops at the right hand switch and will not reverse. It is the only train of my three that does this
This is a common problem with FasTrack Remotes and Manual switches. It is relative to where the center roller pickup is in relation to the wheels (common connection to outter track rails). Solution is to put electrical tape on the outter rail that forms a V between the turn in and the straight away. This elliminates about 1.5" of track discontinuity. It also eliminates wheel sparking that pits the surface of the outter rail. Wish I had a better solution short of taking the switch apart and doing some rewiring.
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Train engine wont run
I made a mistake. My Train is not a Darda top train. Mine is a gp38 that wont run.
Top Lionel Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
