With a heat pump the indoor fan coil does not have a yellow wire that is true your yellow wiring comes from the thermostat which is a 6 wire or 8 which is also true coming from the outdoor condenser you must connect the yellow coming from the condenser and the yellow coming from the thermostat inside the fan coil cabinet the purple is for heating
1992 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Yellow Radio Switched 12V+ Wire: Yellow/Red Radio Ground Wire: Black Radio Illumination Wire: Red/Black Radio Dimmer Wire: N/A Radio Power Antenna Trigger Wire: Yellow/White Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 6 1/2? Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/Green Left Front Speaker Wire (-): Gray/Black Right Front Speaker Wire (+): Red/Green Right Front Speaker Wire (-): Brown/Black Rear Speakers Size: 6 1/2? Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Blue/Yellow Left Rear Speaker Wire (-): Gray/White Right Rear Speaker Wire (+): Red/Yellow Right Rear Speaker Wire (-): Brown/White
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Black Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange/White Car Stereo Antenna Trigger Wire: Yellow Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 3 1/2? Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Green Left Front Speaker Negative Wire (-): Green/Yellow Right Front Speaker Positive Wire (+): Purple Right Front Speaker Negative Wire (-): Purple/Yellow Car Audio Rear Speakers Size: 6? x 9? Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Blue/Red Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Black Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange Car Stereo Antenna Trigger Wire: Yellow Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 3 1/2? Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Green Left Front Speaker Negative Wire (-): Green/Yellow Right Front Speaker Positive Wire (+): Purple Right Front Speaker Negative Wire (-): Purple/Yellow Car Audio Rear Speakers Size: 6? x 9? Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Blue/Red Right Rear Speaker Negative Wire (-): Brown/Yellow
Car Radio Battery Constant 12v+ Wire: White/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Red Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Antenna Trigger Wire: Yellow/White Left Front Speaker Positive Wire (+): Blue/Green Left Front Speaker Negative Wire (-): Gray/Black Right Front Speaker Positive Wire (+): Red/Green Right Front Speaker Negative Wire (-): Brown/Black Left Rear Speaker Positive Wire (+): Blue/Yellow Left Rear Speaker Negative Wire (-): Gray/White Right Rear Speaker Positive Wire (+): Red/Yellow Right Rear Speaker Negative Wire (-): Brown/White
Here is the complete discription of what each wire color does. Please rate this info.
1991 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Yellow Radio Switched 12V+ Wire: Yellow/Red Radio Ground Wire: Black Radio Illumination Wire: Red/Black Radio Dimmer Wire: N/A Radio Power Antenna Trigger Wire: Yellow/White Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/Green Left Front Speaker Wire (-): Gray/Black Right Front Speaker Wire (+): Red/Green Right Front Speaker Wire (-): Brown/Black Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Blue/Yellow Left Rear Speaker Wire (-): Gray/White Right Rear Speaker Wire (+): Red/Yellow Right Rear Speaker Wire (-): Brown/White
Your stock radio should have had a wire that does this. It may not be yellow so look up the wiring diagrams for your car. If you can't find it by doing that, then look up a diagram of your use box. Sometimes there's a diagram on the back of the fuse panel cover or somewhere around there that tells you what fuses are from what. You can then run a new wire if you have to.
