Wer can i buy a im250 paslode driver blade?
Locate the part number online by searching for the tool's model number "parts list" Once you have that information you can visit you local Fastenal and they can order it for you. Paslode will not sell directly to the public on spare parts. They will point you in the direction of a service center. I only know of two: Fastenal and Fasteners Inc.
SOURCE: paslode im250 fan comes on, fuel cell good ,fires
Please make sure use by date is current on bottom of fuel cell. If no date buy new fuel cells with useby date. Fuel has lost its ignition flash point. please reply.
SOURCE: Hi how to change the motor in paslode IM250
There is a small torx bolt in the fan, heat the bolt up to losen it, then remove fan.
Now remove spark plug lead and unplug the wires to the butterfly board.
Then remove the circlip that is holding the outer rubber attached to the fan.
Hope this is some help. any problems contact your nearest paslode repair agent.(check on the paslode web site for your local repair agent)
Good luck.!
SOURCE: how do you clean the cylinder of an paslode im250?
The tool has to be complety torn down to clean out cylinder area and to check for wear on the orings inside of cylinder. Not a quick or easy job.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
