Compaq Armada 3500 Notebook Logo
Posted on Sep 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Laptop doesnt go past the Compaq Screen!
I turn on the laptop and it show the compaq logo then a blank screen i tried hitting F8 this took me to the scrren to start in safe mode and then it asks what system i want to run and has windows xp select so i hit enter and it does nothing. HELP!
  • jjarman Sep 26, 2008
    I bought the computer used it didnt come with any of the disk
Anonymous
Level 2:
  • Expert 158 Answers
  • Posted on Sep 26, 2008
Anonymous
Expert
Level 2:
Answers
158
Questions
Helped
36713
Points
401
You have to reinstall the windows
[email protected]
  • Anonymous Sep 26, 2008
    you have to buy xp service pack2 cd from computer stores
3answers
Compaq cq60 doesn't start
press F8 while starting up if you get screen select safe mode then if the computer starts; go to Start->All Programs->Accessories->system tools->System restore.
If works good, if not then call tech support. Also call tech support if computer not starting up in safe mode
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
2helpful
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
1helpful
2answers
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Laptop powers on disk light flickers & does not start up. The fan is working.Blank screen, when connected to external screen still no output
upon turning the computer on keep hitting the F8 key and see if a repair screen appears. If not the hard drive is gone or the disply is at fault
2answers
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
2helpful
Display does not work (blank screen) on Compaq CQ60-DX214
1. try reloading ur OS (Windows)
2. check ur RAM
1helpful
Finding info on how to change Compaq 6720s bios logo
just tell bios to blank the screen on start up then go into windows and see if in the display section you can stop the compag logo from going on, and also have a blank screen for your screen saver.
1helpful
My laptop is showing blank screen after restarting
try starting your laptop in safe mode by presssing f8 during the booting process, then check whether its boot or not
Laptop frozen
Sounds like you're not getting out of the Post....when starting up try getting in to the post screen. To do so is different with most mfgs but it's usually one of the 'F' keys (F8,F2,F9, etc)
Some times the start screen will even show you what options are available. Either way you'll need to see where the system is hanging.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
