APS787 Prestige Remote Start and Security System w/Keyless Entry Logo
Anonymous Posted on Nov 09, 2011
Prestige remote battery died but need to turn alarm off.
5 Related Answers
Anonymous
  • Posted on Oct 22, 2008
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Anonymous
  • 165 Answers
  • Posted on May 11, 2009
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Anonymous
  • 1615 Answers
  • Posted on Dec 10, 2009
SOURCE: How can I disarm a prestige car alarm system
there is no way to do it at home
If it were that easy a theif would know how to do it also.
Your going to have to get a new remote programmed
Anonymous
  • 18 Answers
  • Posted on Nov 17, 2010
SOURCE: I have a prestige remote start alarm. When i try
Could be several causes for this...most likely there's a safety check feature that keeping the remote start from activating. Most remote start systems have a shutdown diagnostic feature that will indicate why the system is immediately shutting down before the remote start is activating. Check in the installation manual towards the back for how to initiate the shutdown diagnostics for your particular model. Some basic things that would keep a remote start from working would be the brake wire connected incorrectly, an improperly installed hood pin, no tachometer signal programmed, or improper starter wire connections. If everything seems to check out ok, put a voltmeter in the yellow 12 gauge wire at the ignition harness and see if you get 12 volts during both crank with the key and crank via the remote starter. If you don't get anything during crank with the remote starter than there's an underlying issue that needs to be addressed first to pinpoint the exact problem. Email me if you have any other questions, [email protected]
logosc75
Larry Spears
  • 625 Answers
  • Posted on Jul 21, 2011
SOURCE: i have a prestige alarm system on my car. my car won't start
If this is a wireless ignition system (no metal stem on key) then the issue may be with the bypass module. The unit may need to be reset if the technician cut wires during the installation.
1helpful
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Remote died with alarm set. How do I turn off the alarm without remote?
Hello again, to turn off alarm with out remote, trace wires to the alarm horn, undo positive lead.
Hi ,, i have a prestige remote start. model aps- 787n. the alarms lock and unlock ,start and turns off the engine quite ok,, sometimes it is a bit hesitant ,, the only problem is that the valet switch is...
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help
thanks
1helpful
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
9helpful
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
My battery died in my car i got a knew battery now my alarm is keeping it from starting
If the remote fails to disarm the alarm, manually disarm the system by turning the ignition on, then press and release the valet switch. You should hear two chirps, start the vehicle.
I need to see if a add on remote start will work with my prestige
The APS9076 is a OEM add-on remote start module only and not an alarm. Are you trying to add or find a remote to an existing Prestige alarm or installing one?
46helpful
5answers
MSB....
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
