SOURCE: Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
SOURCE: Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
SOURCE: Kenmore HE3 lock latch stuck with door open
ok nice details..all you can do is replace the lock latch,,its not to costly,,change the catch while your there,,,lock part number is,,8181700 and catch part number is 8181651..it will be better just to replace it in the long run ,,,onthejob..
SOURCE: Hotpoint WT761 washing machine - Error code F-10
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
