Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
Does unit make temp? Try cleaning the condenser coil. This is located in front of the compressor. Give some more specs and serial number and I'll give you a hand with this.
