2006 Honda Accord Logo
Posted on Sep 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Security System Alarm Activates in damp weather
I have a 2006 Honda Accord. The problem with this issue is it is not constant, but intermittant. When the weather is damp or it has just stopped raining when we go to use the key fob to get in the car, the car doors do not open. None of the functions on the key fob seem to work (and I have replaced the battery in the fob). Then when the car door is manually opened using the key the car alarm starts and will not shut off. At times we can correct it by closing the car door and pressing the lock button once inside the car. Once the functions of the key fob start to be recognized the alarm stops and everything works as expected. This never occurs when the weather is dry. I have had the car battery checked as a technician said the security system may be noticing a weak battery but the battery always tests ok when I get it to the service station.
Anonymous
Level 2:
Sergeant:
  • Expert 350 Answers
  • Posted on Oct 08, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
350
Questions
0
Helped
152727
Points
757
Hi seems like water is getting inside the drivers door and getting on the alarm switch inside the door or it could just be afaulty alarm switch its the micro switch that connects to the door lock yatse210456
1helpful
How do I shut off my alarm?
Getting into a car that has the security system by unlocking the door with the key will set the alarm off. Usually you can relock and unlock the door with the key and the alarm will be turned off. There are several things that can set off an alarm depending on the sensors, so do you have a remote key FOB and if so does it work. I am including a link to Honda Tech article that may help you out:
http://honda-tech.com/honda-accord-1990-2002-2/how-disable-factory-security-system-1638886/
What is P0344 code for Honda Accord 2006 model car
P0344 = Camshaft Position Sensor 'A' Intermittent Interruption
Possible causes:
- Faulty Camshaft Position Sensor
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery
Location of alarm security system
i would go to the honda dealer they can tell u were it is on the car, and give you a diagram of were it is or google its location on that van and see
2005 Honda Accord alarm system won't turn off!
It appears to be a known issue!
https://www.google.com/search?q=2005+Honda+Accord+alarm+system+won%27t+turn+off
I would take it to a good vehicle electrician who has a good scan tool computer to test diagnostics on the whole electrical system.
1helpful
Security alarm on honda accord 1998 continues to soung when car turned on. How can it be shut off?
If you have the PRESTIGE factory alarm system, there should be a very small switch (microswitch) in the left kicker panel. If you move your feet from the brake pedal to the left, you can almost hit it.
2006 honda accord would not start. All the lights
Cold weather is taking it's toll! Sounds like the battery is weak.......
Acura 1.6 el 2000 factory alarm goes wild when damp weather.
check with your local dealer, there where having issues with that and i know they found the fix for it.
Car engine misses.
replace the coil with a Honda coil. never buy after-market ignition parts with Honda's always buy genuine Honda parts. not only will it work better...but its actually cheaper in some cases..plus they have a much better warranty than most auto parts stores. this rule applies to Honda's and Toyota's Ignition system parts. I had similar issues with my old 1989 Honda accord. As an added measure apply "Di-Electric Grease" into all spark plug wire boots to help seal out any moisture (both plug ends and distributor ends). hope this helps.
1helpful
Just replaced the battery and now now alarm system
is the alarm factory? if so a call to the dealer can help
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
