There is fault in the fuel settings, you might need to remove and clean the carburator, clean the air filter and also check if the oil is clogged.
Also remove the plug and check for dirt electrode tips, if so the spark plug must be replaced. Set with the correct gap , test for the spark before it is replaced.
Also check if there is impurities on the fuel. The carburator resetting must be done with care and take help if needed.
Clogged fuel filter??
