Dryer run for ten min. then stops all haet sensor seem to be fine. Is it possible the timer could be sticking causing this
Hi troy crawford, Well if it beeps for 3
times and then shut off when you press start it means that the dryer thinks
that dryer door is open. You will have to replace your door switch to fix the
problem. or you can also try closing the door normally, then
firmly press on the top edge of the door. You will hear the final latch grab,
then you press and hold the start button. many time it will works... Good
Luck Regards
Good Afternoon Butchie111, thank you for your post!
From the information you have provided your Frigidaire dryer is displaying an error code of "EL8" and it will run for 30 seconds then beep the code. I am showing that "EL8" is an invalid code. It could be a possible miscommunication error so I would suggest performing a reset on your dryer and you can do that by disconnecting power from your dryer for roughly ten minutes. If that does not help your issue could you please provide me with the new error code or inform me if your dryer still displays "EL8"? I look forward to your response. -Matt
