IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
The incomming broadcasting signal cable connector are been standard,since the late 80 til now,why doesn't fit,is a mystries to me.U have cable or satalite dish services wright?Call their customer service,they'll send out a Tv tech. to check it out for u.
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
When watching sport you can only see one score not both.. most frustrating
