If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router,
To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
Hope this helps.
SOURCE: lost username and password for router
To reset the password on the router, switch it off, press and hold the 'reset' button whilst switching the power back on. Keep holding the reset button until all of the LAN lights blink, and your router will be reset back to the way it was when it left the factory.
This only applies to get round the settings installed on the router. You will have to input all the telefonica settings again so that your router can connect to the internet. Resetting the router will not solve any problems regarding telefonica passwords or user names - for this, you (or the account holder) will have to contact telefonica directly.
I hope this helps you.
SOURCE: dlink DI524 Router
admin--user name
blank --password> all lower cases
or try this user nme admin-lower case
password blank
rate me solved if its help full
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W /
6104P
Then
If I forget
my password, what can I do?
I hope this helps.
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
