I am trying to play TV audio from my panasonic viera plasma through my panasonic blueray home theatre. I cannot seem to get any sound through the surround speakers. The tv speakers shut down but the sound doesnt transfer to the blue ray using HDMI cable...any help?
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output is available , ill be honest with you this is a good job .
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
It is very likely that cross talk does corrupt the link but for Panasonic to "blame" anyone else is not very professional. Anyway, if it worked for 6 months perhaps disconnecting the Foxtel IQ and reestablishing the Viera link with the Panasonic devices then reconnecting the Foxtel IQ for another 6 months of happy viewing. This is not a permanent solution but the alternative doesn't seem to be an option.
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Assuming the TV is up and working on its own, here's the simplest approach:
Find the the Audio Out from the TV - either an optical connection or a dual RCA Cable (probably came with the TV) and connect that to an Input on the home theatre receiver. You'll need the right cable depending on whether RCA or Optical. That gets you Surround Sound into the Receiver.
Then, connect a cable from each speaker to the marked terminals on the back of the receiver -- Front L/R, Rear L/R, Center, Subwoofer, etc.
Check out your speaker connections by trying a radio station - should play through the front speakers OK. Then switch to the input you connected the TV into. Once you get the TV Audio playing through the receiver, you can go to your TV setup screen and turn off the internal speakers on the TV.
Hope this is enough to get you going.
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV? I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out. Thanks.
You need a cable from your audio outlet to the home theatre receiver. Veira link is just for the picture. Only one way transmission. Optical cable or the 2 wires. Both options are available.
